copying a spatial table to SDE feature dataset
I copied a spatial table to a database (SQL Server spatial 2012). When I check table in ArcCatalog I see it in Root. I have some feature dataset defined in the same dataset. I can export the table to Geodatabase (Single) but I need to use other name. Is it possible to move this table without changing the name? Also where are the controls for this description in SQL server, in case if I want to only run a script.
