Converting sqlite (spatialite) data to oracle sdo_geometry (using .NET)
Using .NET, I have a sqlite file that I have to import to oracle. The geometry needs to be converted from sqlite (spatialite) geometry column to a sdo_geometry column in oracle:
// Loop through all records in sqlite fileforeach (DataRow row in dsSqLite.Tables["Default"].Rows){ // Get geometry field from sqlite and get it ready for oracle format NetSdoGeometry.sdogeometry geom = row["GEOMETRY"]; // ERROR HERE} When I execute the above, I get an error "Unable to cast object of type 'System.Byte[]' to type 'NetSdoGeometry.sdogeometry'. Also I do not see where to specify the SRID. Does anyone know the correct way to convert the geometry column from spatialite to oracle sdo_geometry?
References:NetSdoGeometry library: https://github.com/mapspiral/NetSdoGeometry
