I have a shapefile of a boundary (polygon) that has the following projection:
NAD_1927_UTM_Zone_11N Projection: Transverse_Mercator False_Easting: 500000.00000000 False_Northing: 0.00000000 Central_Meridian: -117.00000000 Scale_Factor: 0.99960000 Latitude_Of_Origin: 0.00000000 Linear Unit: Meter
Geographic Coordinate System: GCS_North_American_1927 Datum: D_North_American_1927 Prime Meridian: Greenwich Angular Unit: Degree
I need to pull climate data (in netcdf files) that is within this boundary. That data is in x y coordinates and has the following information:Geographic Coordinate System: GCS_North_American_1927 Datum: D_North_American_1927 Prime Meridian: Greenwich Angular Unit: Degree
XLAT
Size: 219x285 Dimensions: londim,latdim Datatype: single Attributes: units = 'deg' XLONG
There's no other metadata, so in order to align these files, I need to convert the shapefile to decimal degrees. I tried using the Project tool, selecting the same coordinate system, but I don't see decimal degrees in the drop-down. Size: 219x285 Dimensions: londim,latdim Datatype: single Attributes: units = 'deg' XLONG
