I have a MapBasic script that divides an irregular polygon into smaller polygons of 1 hectare each.
Would anyone help me to convert the following into an ArcPy script.
' This program requires an open MapInfo Table named woodlots with fields lot (integer) and area (dec or float)Declare Sub MainDeclare Function Calc_height(stand1 as object) as floatDeclare Sub CookieVarH(ByVal width1, height1 as float, sliver1 As Object, cookiecutter As Object)Declare Sub setWoodlot()Declare Sub setTimberlot()Declare sub checkerglobal gs_last_band, gs_project as stringSub Main INCLUDE "C:\program files\MAPINFO\MAPBASIC\MAPBASIC.DEF"INCLUDE "C:\program files\MAPINFO\MAPBASIC\MENU.DEF"Include "icons.def" Set CoordSys Earth Projection 8,33,"m",141,0,0.9996, 500000, 10000000Dim stand1, rectangle1, band1, band2, sliver1, cookie1, sliver2 As Object Dim woodlot1, leftover1, cookie2, right_end1, left_end1 As ObjectDim minX, maxX, minY, maxY, area1, width1, height1, widthend, widthstart As FloatDim diff_y, row_id As FloatDim band_no, woodlot_no, max_band, i, lots as IntegerDim sliver_area As FloatDim mnX, mnY, mxX, mxY As Floatstand1 = selection.objband_no = 1woodlot_no = 1gs_last_band = "false"while CartesianArea(stand1, "hectare") > 1 minX = ObjectGeography(stand1, OBJ_GEO_MINX) minY = ObjectGeography(stand1, OBJ_GEO_MINY) maxX = ObjectGeography(stand1, OBJ_GEO_MAXX) maxY = ObjectGeography(stand1, OBJ_GEO_MAXY) width1 = 1 area1 = 0 height1 = 0 create Rect into variable rectangle1 (minX, minY) (maxX, maxY) height1 = calc_height(stand1) '****** call height create Rect into variable band1 (minX, (maxY - height1)) (maxX, maxY) sliver1 = overlap(stand1, band1) sliver_area = CartesianArea(sliver1, "hectare") lots = round((sliver_area/1),1)' note " height1 = " + str$(height1) + " sliver_area = " + str$(sliver_area) + " lots = " + str$(lots) for i = 1 to lots width1 = 10 area1 = 0 if i < lots then mnX = ObjectGeography(sliver1, OBJ_GEO_MINX) mnY = ObjectGeography(sliver1, OBJ_GEO_MINY) mxX = ObjectGeography(sliver1, OBJ_GEO_MAXX) mxY = ObjectGeography(sliver1, OBJ_GEO_MAXY) do create Rect into variable cookie1 ((mnX) , (mnY)) ((mnX + width1), mxY) woodlot1 = overlap(sliver1, cookie1) area1 = CartesianArea(woodlot1, "hectare") width1 = width1 + 0.1 loop while Area1 < 1 ' if area is > 1 put woodlot in layer and remove from sliver insert into Woodlots (obj,area) values (woodlot1, area1) woodlot_no = woodlot_no + 1 else 'last lot in sliver cut out all woodlot1 = sliver1 area1 = CartesianArea(woodlot1, "hectare") if gs_last_band = "false" then insert into Woodlots (obj,area) values (woodlot1, area1) woodlot_no = woodlot_no + 1 else insert into Woodlots (obj,lot,area) values (woodlot1, 9999, area1) call CookieVarH(width1,height1, sliver1, cookie1) end if end if if lots = 1 then call CookieVarH(500,height1, sliver1, cookie1) end if sliver1 = Erase( sliver1, cookie1 ) sliver_area = CartesianArea(sliver1, "hectare") nextcreate Rect into variable band2 (minX, (maxY - height1)) (maxX, (maxY + 1))leftover1 = erase( stand1, band2 )stand1 = leftover1wend' insert remeinder into tableif gs_last_band = "false" then ' only do if there is a remeinder insert into Woodlots (obj,lot, area) values (leftover1, 9999, CartesianArea(stand1, "hectare")) stand1 = selection.objend if' clean objectsselect * from woodlots' Objects Snap From Selection Tolerance Vector 1 Units "m" commit table woodlotsEnd Sub 'Mainfunction Calc_height (stand1 as object) As Float Dim sliver_area, trunc, height, stand_area, stand_trunc As Float dim bandx, sliver1 as object dim lots as float Dim mnX, mxX, mnY, mxY As Float stand_area = CartesianArea(stand1, "hectare") stand_trunc = int(stand_area) height = 65 mnX = ObjectGeography(stand1, OBJ_GEO_MINX) mnY = ObjectGeography(stand1, OBJ_GEO_MINY) mxX = ObjectGeography(stand1, OBJ_GEO_MAXX) mxY = ObjectGeography(stand1, OBJ_GEO_MAXY) create Rect into variable bandx (mnX, (mxY - height)) (mxX, mxY) sliver1 = overlap(stand1, bandx) sliver_area = CartesianArea(sliver1, "hectare") lots = Round((sliver_area/1), 1) trunc = int((sliver_area/1))' note "sliver_area = " + str$(sliver_area) + "lots = " + str$(lots) + " trunc = " + str$(trunc) if (lots = trunc and trunc 0 ) then ' note "height getting smaller" mnX = ObjectGeography(stand1, OBJ_GEO_MINX) mnY = ObjectGeography(stand1, OBJ_GEO_MINY) mxX = ObjectGeography(stand1, OBJ_GEO_MAXX) mxY = ObjectGeography(stand1, OBJ_GEO_MAXY) while CartesianArea((sliver1), "hectare")/1 > trunc height = height -0.05 create Rect into variable bandx (mnX, (mxY - height)) (mxX, mxY) sliver1 = overlap(stand1, bandx) wend gs_last_band = "false" elseif (stand_area < 1) or (stand_area < (lots*1)) then ' last band ' note " stand_area = " + str$(stand_area) + " lots = " + str$(lots) height = 300 gs_last_band = "true" else ' note "height getting larger" ' if (lots > stand_area) and (lots >1) then ' lots = lots -1 ' end if if lots = 0 then lots = 1 end if gs_last_band = "false" mnX = ObjectGeography(stand1, OBJ_GEO_MINX) mnY = ObjectGeography(stand1, OBJ_GEO_MINY) mxX = ObjectGeography(stand1, OBJ_GEO_MAXX) mxY = ObjectGeography(stand1, OBJ_GEO_MAXY) while CartesianArea(sliver1, "hectare")/1 < lots height = height + 0.05 create Rect into variable bandx (mnX, (mxY - height)) (mxX, mxY) sliver1 = overlap(stand1, bandx) wend end if Calc_height = height height = 65' note " calc_height = " + str$(height)End Function Sub CookieVarH (ByVal width1, height1 as float, sliver1 As Object, cookiecutter As Object) Dim mnX1, mnY1, mxX1, mxY1 As Float mnX1 = ObjectGeography(sliver1, OBJ_GEO_MINX) mnY1 = ObjectGeography(sliver1, OBJ_GEO_MINY) mxX1 = ObjectGeography(sliver1, OBJ_GEO_MAXX) mxY1 = ObjectGeography(sliver1, OBJ_GEO_MAXY) create Rect into variable cookiecutter ((mnX1) , (mnY1)) ((mnX1 + width1), mxY1)End Sub
