Converting large rasters to NumPy
I have a geodatabase that contains a large number of raster datasets - there are two rasters for each country in the world, and they are very large, in some cases up to 3GB per raster dataset.
I need to convert these to NumPy arrays so as to run an analytical program that I wrote on them, but I'm hitting a memory error when my script tries to convert the first raster dataset. The script creates a list of all of the rasters in the dataset (rasterList), then grabs the country codes at the end of each raster dataset name and populates a new list of all the country codes. I then delete rasterList, and iterate through the country codes, converting rasters to either 'GLUR_'+code or 'Pop00_'+code. I delete each raster from memory after it is converted, but the program doesn't even get that far...
The code is:
import arcpy, os import numpy as np from arcpy import env env.workspace = "J:/Data/CISC.gdb" filepath = "J:/LIVE/" rasterList = arcpy.ListRasters("G*") codeList = [] for raster in rasterList: codeList.append(raster[5:]) del rasterList for code in codeList: print code inputGLUR = arcpy.Raster("J:/Data/CISC.gdb/GLUR_"+code) lowerLeft = arcpy.Point(inputGLUR.extent.XMin, inputGLUR.extent.YMin) cellSize = inputGLUR.meanCellWidth print "Converting GLUR_"+code, "to NumPy array" arr = arcpy.RasterToNumPyArray(inputGLUR, nodata_to_value=0) os.chdir("J:/LIVE/NumPy_GLUR") numpy.save("GLUR_"+code+".npy", arr) print "GLUR Converted" del inputGLUR del arr inputPop = arcpy.Raster("J:/Data/CISC.gdb/Pop00_"+code) lowerLeft = arcpy.Point(inputPop.extent.XMin, inputPop.extent.YMin) cellSize = inputPop.meanCellWidth print "Converting Pop00_"+code, "to NumPy array" arr = arcpy.RasterToNumPyArray(inputPop, nodata_to_value=0) os.chdir("J:/LIVE/NumPy_Pop") numpy.save("Pop00_"+code, arr) print "Population array converted" del inputPop del arr and yields this error:
Traceback (most recent call last): File "J:\PYTHON\RasterToNumPy.py", line 21, in arr = arcpy.RasterToNumPyArray(inputGLUR, nodata_to_value=0) File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\__init__.py", line 2244, in RasterToNumPyArray return _RasterToNumPyArray(*args, **kwargs) MemoryError This is on a computer with an i7 processor and 16GB RAM. The data is stored on an external disk. Any ideas on how to handle rasters of this size?
