thanx to this forum i have recently discovered the http://overpass-turbo.eu/ service for selecting and "downloading" selected data from open street map.
i am trying to get a shapefile out of a group of relations (hiking trails, that are relations built on actual lines in osm database), my goal is to obtain a line-shapefile with all the hiking trails in a given area and their attributes.
actually, i can select and download to gpx, kml or geojson the data i'm looking for with a simple query,but i have problems in the conversion to shapefile: GPX and KML can be easily converted, but they dont have all the tag info i need.
on the other hand, geojson, when opened, contains this data, but when converted to shp (for example with an online tool like mapshaper or similar (i have used http://converter.mygeodata.eu/) the table looks funny and attributes are not set correctly: there are only 2 attributes
id and @relations, the first containing the way ID, the second containing all attributes including the tags i'm looking for, in brackets, separated by commas.
how do i convert this geojson in a usable shapefile, with a column for relation number and a column for each tag?
