I am looking to convert a .DEM exported from AutoCad to a floating point raster file type (.FLT) utilizing QGIS to implement in HEC-RAS Mapper.
This is accomplished easily in Arc using the Raster>Float option. Referencing ESRI Supported Formats it does not appear the .FLT format is proprietary. It does mention "Write—Only via Raster To Float tool, or developer code" which could suggest that it could be incorporated into QGIS. Although, the QGIS Raster>Translate does not offer the .FLT format.
Is there open-source workaround to convering DEM to .FLT?
