Convert Titleblock from AutoCad .dwg into template for ArcMap Layout view.
We have a company standard template for figures in a CAD .dwg file, it is in paper-space (equivalent to layout view) in the CAD file.
I would like to use the template without having to re-create it from scratch in Arc.
For Some reason, I am not able to save the template as a .mxt, as I have seen suggested in other possible solutions.
I am using Autocad Civil 3D 2013 and ArcMap 10.2.1
The template has a file path that updates to where the file is stored and several standard fields for information to be updated manually for each individual figure but when I try to use these features in ArcMap, they are not accessible. ArcMap seams to treat the whole template as a single graphic.
I would like to create an ArcMap template with the same features as the .dwg title block, any help would be greatly appreciated
