I have a sql server table with Geo spatial data. An example of row would be (with Column names):
type: streetlinecode: 231001geog: 0xE6100000011 ........Centroid 0xE61000000C.......geom: 0xE6100000011 ........I am using C# with MVC3 to draw the above shapes on leaflet map. I am fetching the above sql data into a datatable. Using the sql function "ToString()" on column "geom" I get the following:
"LINESTRING (-1.131510412 52.65531, -1.13286 52.65559)","POLYGON ((-1.1116360 52.6409953, -1.1116683 52.6413, -1.11146723 52.641317, -1.11133263 52.6413572, -1.1113059))",The question is how do I convert the above to GeoJSON to be able to plot on the leaflet map. Here is an example of the expected output (GeoJSON) I want:
var geojsonFeature = { "type": "Feature", "properties": { "name": "Coors Field", "amenity": "Baseball Stadium", "popupContent": "This is where the Rockies play!" }, "geometry": { "type": "Point", "coordinates": [-104.99404, 39.75621] }};
