Convert non-spatial Oracle table to spatial Oracle table in a different database
I'm trying to use ogr2ogr to convert data from a non-spatial table (has X & Y values) in an Oracle database (1) to a spatial format in a different Oracle database (2). This will be scheduled to run daily to overwrite the table in Oracle database (2) each time.
I have it working using a ogr2ogr's Virtual File Format, with the file Oracle.vrt which is like:
OCI:userid_1/password_1@database_instance_1:TEST_X_Y TEST_X_Y wkbPoint EPSG:27700 Then using the following ogr2ogr command:
ogr2ogr -update -overwrite -f OCI OCI:userid_2/password_2@database_instance_2:TEST_OGR_IN Oracle.vrt TEST_X_Y -lco OVERWRITE=YES -lco SRID=27700 -nln TEST_OGR_INNow this works and creates the spatial table in the Oracle database (2) fine, but when I run the ogr2ogr command a second time I get an error like:
ERROR 1: ORA-00001: unique constraint (MDSYS.UNIQUE_LAYERS) violatedORA-06512: at "MDSYS.SDO_GEOM_TRIG_INS1", line 43ORA-04088: error during execution of trigger 'MDSYS.SDO_GEOM_TRIG_INS1' in INSERT INTO USER_SDO_GEOM_METADATA VALUES ('TEST_X_Y',...The table (TEST_OGR_IN) still gets overwritten/updated in the Oracle database (2) but the problem appears to be that ogr2ogr has inserted values into the USER_SDO_GEOM_METADATA table on the Oracle database (1) for the non-spatial table (TEST_X_Y) and is violating an index/constraint?
Although the process works, I'd like to understand why the error is happening and how I can avoid it. Many thanks for any assistance offered.
