I am running arcmap 10.2.2 but need to open an mxd saved using 10.3. I do not have access to 10.3. I have an arcpy tool which will do the conversion but it is not working from within 10.2.2. Does anyone know if it is possible to do this from within 10.2.2. I get an error message saying I do not have write access to the file. Any help would be much appreciated! The script is as follows:
import arcpy, sys, os, string mxdList = string.split(arcpy.GetParameterAsText(0), ";") outloc = arcpy.GetParameterAsText(1)version = arcpy.GetParameterAsText(2)suffix = "_"+ version.replace(".", "")for item in mxdList: item = item.strip('\'') mxd = arcpy.mapping.MapDocument(item) base = os.path.basename(item) base = os.path.splitext(base)[0] + suffix + os.path.splitext(base)[1] mxd.saveACopy(outloc + os.sep + base, version) arcpy.AddMessage(os.path.basename(item) + " has been converted")
