Convert coordinates from readShapePoly in R to long-lat coordinates
I'm trying to find some centroids of a shapefile for Danish municipalities and afterwards find the driving time between them. I use R's readShapePoly function from maptools combined with the gCentroidfunction from rgeos, and everything works. However, I get spatialpoints such as
SpatialPoints: x y 1 571860.7 6225016 Coordinate Reference System (CRS) arguments: NA Which is clearly not something I can use in Google to grab travel times. I'm looking for a way to convert these numbers to longitude-latitude, but have no idea how.
When I read the data using readOGR from the rgdal library I get the same coordinates but it tells me the following about what I assume is the projection (but the coordinates are the same)
Slot "proj4string": CRS arguments: +proj=utm +zone=32 +ellps=intl +units=m +no_defs Reproducible example: I've put the data for the example here: https://github.com/sebastianbarfort/shapefiles
This should reproduce the problem:
library(maptools) library(rgdal) library(rgeos) map = readShapePoly("~/Downloads/shapefiles-master/kommuner1983.shp") centroid = gCentroid(map) centroid
