I have converted feature class from a geodatabase to shapefile, and after that I have updated some polygons in shapefile. Now I want to get back to the same feature class or a fress/new feature class in the same geodatabase. How Can I perform this task in ARCGIS ?
The Problem is: I have a defined domains(codded-value-domain) in geodatabase (a dropdown will come for updation of attributes while editing(dropdown contains different land use class names and their codes)), but after converting from feature class to shapefile,in attribute table I only got codes for the landuse classes. After that I have updated some polygons in shapefile with same codes, So now How can I get back to the same geodatabase as a feature class which has same domains??
any solution either its direct method or some script in arcpy is appriciated
