Conversion between semicircles and latitude units
I've recently come across the semicircle unit that is used to describe a latitude and longitude using the maximum precision allowed by a 32-bit number. The conversion here is given as degrees = semicircles * ( 180 / 2^31 ), semicircles = degrees * ( 2^31 / 180 ).
However it doesn't explain if this should be used differently for latitude since the maximum allowed number of semicircles is 2^31, and if you substitute this into the equation you get the answer 180 degrees, but latitude only goes up to 90.Would a different conversion between latitude be used instead? Such as, degrees = semicircles * ( 90 / 2^31 ), semicircles = degrees * ( 2^31 / 90 )?
If so then you wouldn't be using the 'semicircle' as a unit for latitude, more like a quarter circle in this case.
Has anybody else come across this issue?
Thanks.
