I'm trying to construct voronoi diagram from grid of points using modified code from here. This is SQL query after my modifications:
DROP TABLE IF EXISTS example.voronoi;WITH -- Sample set of points to work with Sample AS (SELECT ST_SetSRID(ST_Union(geom), 0) geom FROM example."MeshPoints2d"), -- Build edges and circumscribe points to generate a centroid Edges AS ( SELECT id, UNNEST(ARRAY['e1','e2','e3']) EdgeName, UNNEST(ARRAY[ ST_MakeLine(p1,p2) , ST_MakeLine(p2,p3) , ST_MakeLine(p3,p1)]) Edge, ST_Centroid(ST_ConvexHull(ST_Union(-- Done this way due to issues I had with LineToCurve ST_CurveToLine(REPLACE(ST_AsText(ST_LineMerge(ST_Union(ST_MakeLine(p1,p2),ST_MakeLine(p2,p3)))),'LINE','CIRCULAR'),15), ST_CurveToLine(REPLACE(ST_AsText(ST_LineMerge(ST_Union(ST_MakeLine(p2,p3),ST_MakeLine(p3,p1)))),'LINE','CIRCULAR'),15) ))) ct
FROM ( -- Decompose to points SELECT id, ST_PointN(g,1) p1, ST_PointN(g,2) p2, ST_PointN(g,3) p3 FROM ( SELECT (gd).Path id, ST_ExteriorRing((gd).geom) g -- ID andmake triangle a linestring FROM (SELECT (ST_Dump(ST_DelaunayTriangles(geom))) gd FROM Sample) a -- Get Delaunay Triangles )b ) c )SELECT ST_SetSRID((ST_Dump(ST_Polygonize(ST_Node(ST_LineMerge(ST_Union(v, ST_ExteriorRing(ST_ConvexHull(v)))))))).geom, 2180)INTO example.voronoiFROM ( SELECT -- Create voronoi edges and reduce to a multilinestring ST_LineMerge(ST_Union(ST_MakeLine( x.ct, CASE WHEN y.id IS NULL THEN CASE WHEN ST_Within( x.ct, (SELECT ST_ConvexHull(geom) FROM sample)) THEN -- Don't draw lines back towards the original set -- Project line out twice the distance from convex hull ST_MakePoint(ST_X(x.ct) + ((ST_X(ST_Centroid(x.edge)) - ST_X(x.ct)) * 2),ST_Y(x.ct) + ((ST_Y(ST_Centroid(x.edge)) - ST_Y(x.ct)) * 2)) END ELSE y.ct END ))) v FROM Edges x LEFT OUTER JOIN -- Self Join based on edges Edges y ON x.id y.id AND ST_Equals(x.edge,y.edge) ) z
Below - result of my query.
As you can see I get "almost" correct voronoi diagram, except highlighted points which don't have unique polygon. Below is what QGIS algorithm produce and what I would like to obtain from query. Any sugestions where is the problem with my code?
