I use Cycle.travel to draw cycling routes. However, the Android application I use on my smartphone only supports KML.
As an alternative to GPSVisualizer, I tried the command-line utility GPSBabel, but, besides turning a compact 5K GPX into a much bigger 80K KML, the route is displayed as a long series of waypoints instead of a simple line:
Does someone know of an alternative to GPSBabel?
Thank you.
PS: Here's a sample from the source GPX file and the KML generated by GPSBabel:
GPX
ACTIVE LOG…KML from GpsBabel
… 2.252120 48.785320 15131.199708 .5 http://earth.google.com/images/kml-icons/track-directional/track-none.png 0 ……Distance 9.8 mi ]]> Points ACTIVE LOG-0 Longitude: 2.316100 Latitude: 48.815690 Heading: 2.0 … Path #lineStyle 1 2.316100,48.8156902.315900,48.815790…2.189150,48.7545602.188140,48.755100
Thank you.
GPX
