I was recently asked about what guidelines there are for authoring workspaces in FME.
As you might know, we have the idea of Best Practices in FME; a concept about what makes a workspace, a good workspace.
Chapter three of our training course covers Best Practices. It mentions annotations, bookmarks, debugging, project organization, and a lot more. We also have a sample project that we use for certification candidates. It’s an example of what a project ought to look like – both in the workspace and for its documentation.
So, I can tell you what makes a workspace good – but it’s perhaps a little harder to say what makes a workspace bad. I mean – if a workspace runs to completion, and produces the output you want, it can’t be bad… can it?
Code Smell
When I looked up methods to identify bad code, I found that it is not always a firm answer. Instead you have to look for identifiers that Wikipedia calls Code Smell. It states:
So, can I find any identifiers that suggest an FME workspace is… a bit whiffy?
Duplication
Duplication is the biggest red flag of all.
Objects repeating themselves in a workspace are like the blue cheese of FME (a noticeably sharp aroma that taints everything it comes in contact with).
In particular, these are bad duplications:
Complexity
I found another quote, which I think is great because it is a dilemma in how we evaluate workspaces for certification:
These workspaces are the bad wines of FME: the label says it’s a big, bold, oaked nose; with a complex backdrop of juicy raspberries, velvety vanilla, opulent cigars, and spicy figs. But after lengthy sampling, you figure out it reminds you more of used gym socks.
These are clues that there might be a problem:
Bulletproofing
By bulletproofing I mean that you design a workspace with the assumption that problems will arise – therefore you build in methods to handle failure. Error trapping is – I think – the term used in development.
Bulletproofing can simply be adding a test or filter transformer to weed out bad features – usually before they get to the point at which an error would occur.
However, though easy to describe, it’s not so easy to notice when bulletproofing is missing. These are the wet dogs of FME! You have to put your nose up close and sniff hard to catch the odour (but, boy, when you do!) – I would double check my workspace in these scenarios:
If you can’t be sure what data is coming, you better be prepared for the worst!
Deodorizing a Workspace
In the same way you might think your seafood dinner has a delicate aroma of the ocean, it can be hard to perceive your own workspaces as being anything other than delightfully fragrant! The solution to both problems is much the same: you need a good friend to point out the problem.
At Safe, our developers don’t commit their work to the FME product until it has been code-reviewed by a colleague. So that’s what I’m suggesting you try. In particular:
You would only need to get a group of people together for a code review meeting when the project is really large and complex, or there is a disproportionately high-cost associated with failure.
It really is worth doing, and both reviewer and reviewee will perhaps learn about techniques they weren’t aware of.
FME Golf
The other interesting thing I found while researching code quality, was the concept of “code golf“.
Like traditional golf, where the object is to play a round in the fewest number of strokes, code golf requires a developer to solve a problem using the shortest amount of code possible. For example this snippet of code:
!(y%100
Code Smell
Code smells are usually not bugs—they are not technically incorrect and do not currently prevent the program from functioning. Instead, they indicate weaknesses in design that may be slowing down development or increasing the risk of bugs or failures in the future.
In FME terms, your workspace runs, it produces the output you need, but… further editing may be harder than it should be, plus even if the workspace runs now, maybe it might fail in the future.
Duplication
- The same transformer or – worse – group of transformers, occurring multiple times with very little difference
- Multiple feature types all connected to the same transformer (ever heard of a Merge Filter?)
- Multiple Readers all reading the same format of data (one Reader can read multiple datasets)
Complexity
one way [to code] is to make it so simple that there are obviously no deficiencies; the other way is to make it so complicated that there are no obvious deficiencies
A workspace does not need to be complex to be a good project. It can be carrying out a complex process in a simple way. But sometimes I see a workspace that’s so complex it takes me hours to determine whether there really are no deficiencies, or whether they are just really well-hidden.
These workspaces are the bad wines of FME: the label says it’s a big, bold, oaked nose; with a complex backdrop of juicy raspberries, velvety vanilla, opulent cigars, and spicy figs. But after lengthy sampling, you figure out it reminds you more of used gym socks.These are clues that there might be a problem:
- Low Level Complexity: Using FME functions and factories inside a workspace, or an excess of Python scripting
- Multiple workspace complexity: This workspace calls that one, which calls this one, which runs Python to call that one… etc
- Multiple Connections: When your connections are so dense they form a moiré pattern, it’s time to reevaluate your workspace!
- Excess Debugging: When you have Loggers, Inspectors, and breakpoints attached to just about every transformer
Bulletproofing
- Transformers whose parameters accept attribute values (what’s going to happen to a null or missing value?)
- Transformers and formats that accept limited geometry types (what’s going to happen to unsupported geometry?)
- Source formats that support aggregates (not all transformations allow aggregate features)
- If the workspace will be deployed on a different operating system (will file paths be an issue?)
- If the workspace will be deployed on FME Server or FME Cloud (will all custom resources be available?)
- Don’t deliver a project until an FME-using colleague has examined your workspaces
- Make a checklist of issues to look for (like those I’ve mentioned above)
- Make a formal process (e.g. put a check-box in your records) so you don’t forget or dodge it
FME Golf
!(y%100
