Code converting lat/long coordinates (WKT) to polygon (shapefile) not working
I am having a problem converting WKT to shapefile. I have a csv file consisting of three columns: ID, Name (of the area) and WKT comprising set of lat/long coordinates of area boundaries. For example, first row looks like this:
1700003504,Westbourne Green,"(51.5212 -0.2011,51.5213 -0.2033,51.5217 -0.2032,51.5217 -0.204,51.524 -0.2039,51.524 -0.2046,51.5258 -0.2045,51.5258 -0.2024,51.5253 -0.2024,51.5253 -0.2009,51.5248 -0.201,51.5248 -0.1995,51.5244 -0.1995,51.5244 -0.1988,51.5239 -0.1988,51.5239 -0.1981,51.523 -0.1982,51.523 -0.1989,51.5226 -0.1989,51.5226 -0.1996,51.5221 -0.1996,51.5221 -0.2003,51.5217 -0.2004,51.5217 -0.2011,51.5212 -0.2011)"
I stumbled upon the code online which makes use of ArcPy's FromWKT function, but it does not appear to work for some reason. The code is as it follows:
# convert well known text to geometry, and compile shapes into a single feature class...# 11/15/2012import arcpy#reference: https://geonet.esri.com/thread/63090File = "H:\\...\\ClgBoundaries1.csv"# dimension the WKT string field and poly ID field...# the field holding the WKT string...field1 = "Wkt"# the field holding the unique ID...field2 = "Id"#the field holding the namefield3 = "NAME"# set up the empty list...featureList = []#spatialreference WGS1984sr = arcpy.SpatialReference(4326)# iterate on table row...cursor = arcpy.SearchCursor(File)row = cursor.next()while row: print (row.getValue(field2)) print (row.getValue(field3)) wkt = row.getValue(field1) # this is the part that converts the WKT string to geometry... temp = arcpy.FromWKT(wkt, "") # append the current geometry to the list... featureList.append(temp) row = cursor.next()# copy all geometries in the list to a feature class...arcpy.CopyFeatures_management(featureList, "H:\\...\\ClgBoundaries.shp") # clean up...del row, temp, WKT, File, field1, featureList, cursorTextual output of the code are only first area's ID and first area's name,1700003504Westbourne Greenbut nothing else happens. This error message shows:
Traceback (most recent call last):File "H:\...\WktConversion.py", line 32, in temp = arcpy.FromWKT(wkt, "")File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\__init__.py", line 1627, in FromWKTreturn gp.createObject("_wkt", wkt_string, spatial_reference)File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 379, in createObjectself._gp.CreateObject(*gp_fixargs(args, True)))RuntimeError: Object: CreateObject _wkt not validWhat should I do to successfully convert WKTs to SHP polygons?
