Clip data frame using Outline of Selected graphic(s) in ArcGIS Desktop?
I did a subtraction of a data frame in ArcGIS using the following steps.I prepared a layout in ArcGIS. There is a lot of empty space at the top of layout page. So I want to remove this space. I used a graphic operation to remove it.
  1. Created a graphic rectangle that the same size as the Data Frame
  2. Created another rectangle covering empty space
  3. Selected rectangle 2, then rectangle 1, and chose--> Graphic Opperations --> Subtract.
  4. In the last step, I wanted to clip the subtracted image by "Outline of Selected graphic". But 'Outline of selected graphic' is not activated. I can't click it. I'm wondered why this is not activated?
