I have the standard geoprocessing service, Clip & Zip, which references a spatial reference folder containing various coordinate systems (in prj). The service works in geocortex via the standard 'Extract.xaml' file. However I need the ability to Change coordinate systems on export. The reason being, ESRI Base maps are on WGS so the geocortex instances / map services are WGS.
Anyone had any luck getting clip n zip working with the ability to select a coordinate system via geocortex? We are happy to have the data exporting in its proprietary coordinate system (so no transformation required), just not the web viewer coordinate system.
