Changing Mosaic Dataset Properties in Map Document using Arcpy
does anyone know if it is possible in ArcGIS 10.3 to access and change mosaic dataset properties within a map document using arcpy? I am trying to write text into the symbology description in the boundary layer of a mosaic dataset (not the description field on the layer properties general tab of the mosaic dataset).
Thanks.
