Change Symbology with different Column Value
I am trying to change Cadastre colours when the values of the box EXTRA is set to 0,1 or 2.So basically, I need the default values set to 0 (already completed).Properties that have to be invested have a value set to 1 (completed).Properties with further information needed value set to 2 (completed onsite).
To make it user friendly I would like to set up the symbology colour to change the polygons to different colours depending on the EXTRA value.
0 = clear1 = green2 = red
I have tried both Quantities and Multiple Attributes but neither get the result I am after.
Using the 'Graduated Colors', changing Fields Value to EXTRA only gives one symbol when I would want three? If I have three then I will be able to change the range and respective colours.
Thanks in advance.
