Change GRASS module default parameter
I´m new to Qgis and GRASS.I need to change the default parameter skip of the module r.to.vect.lines, from its default value of 10 to 1.How can I do this?
r.to.vect.lines [-v] input=name output=name [skip=integer] [--help] [--verbose] [--quiet] [--ui]
Thank you
