I am building a spatial view using SQL Server Management Studio 2014. One of the tables I am using to build this view has field names that are not compatible with esri; the field names have slashes, hyphens and spaces.
Is it possible to rename the fields of the view being created as the view is being created? So something like;
CREATE VIEW dbo.NewView ASSELECT * FROMdbo.tableAINNER JOIN dbo.tablebON dbo.tableA.UID=dbo.tableB.UIDEXEC sp_rename 'dbo.NewView.Bad/field-name','GOOD_FIELD_NAME'The EXEC sp_rename works if I run it by itself after the view has been created and on one field at a time, which isn't an ideal solution.
Or is there some way to run a find/replace on the field names of the view after it has been created?
