Change ArcSDE data source for mxds in specific folder using ArcPy?
I've searched all the forums and help and have made progess but recently got an error that has thrown me for a loop - also some mxds are not being changed at all! What I'd like my code to do:Iterate through mxds in a specific folder, change the ArcSDE data source in each layer within an mxd and change it to the new ArcSDE source (we just upgraded our server). Then I'd like to either save over that mxd, or save to a new folder (whatever works!).
Here's the code:
import arcpyimport osfolderPath = "G:\GIS\Services\Test"for fileName in os.listdir (folderPath): fullPath = os.path.join(folderPath, fileName) if os.path.isfile(fullPath): basename, extension = os.path.splitext(fullPath) if extension.lower() == ".mxd": mxd = arcpy.mapping.MapDocument(fullPath) print "MXD: " + fileName arcpy.env.workspace = fullPath mxd.replaceWorkspaces("", "NONE", r"Database Connections\Connection to gisserver.sde","SDE_WORKSPACE") print "successfully changed data sources"mxd.save()del mxdThis worked sucessfully when tested with one mxd in a folder, so i thought it would apply to a folder with more mxds, however
The error I received while attempting to iterate through the folder:
Traceback (most recent call last): File "C:/Users/lyee/Test2", line 10, in mxd = arcpy.mapping.MapDocument(fullPath) File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 608, in init assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename") AssertionError: Invalid MXD filename.
