I have a line feature. I need to create a point feature from it. The point should ideally fall at the center of the line.
I used both CenterPointReplacer and CenterOfGravityReplacer but in some situations the point do not fall on the line. It is at some distance from the line which is not desirable. The picture below illustrators undesirable situation.
As you can see in the picture the point is not on the line. Is there transformer or a way to correct this ?
