CartoDB not showing title or description (or other options)
I'm using CartoDB and I can only get one option every to work cartodb_logo. The rest seem to be ignored. Here's the relevant part of my code. What is wrong with this to cause title and description to be ignored (not on my map)?
var layerSource = { user_name: 'myname', type: 'cartodb', sublayers: [{ sql: "SELECT * FROM mydata", cartocss: "#mydata{marker-width: 10; marker-line-color: #FFF; marker-line-width: 0.5; marker-line-opacity: 1; marker-fill-opacity: 1.0; }" }] }; var options = { https: true, infowindow: true, cartodb_logo: false, //this works fine title: "testing title", //this isn't rendered on map description: "testing description", //this isn't rendered on map shareable: true, //no sharing buttons shown legends: true //no legends either }; var map_object = new L.Map('test_heat', { center: [39.8282, -98.5795], zoom: 5, }); L.tileLayer('https://cartodb-basemaps-{s}.global.ssl.fastly.net/light_all/{z}/{x}/{y}@2x.png', { attribution: '© OpenStreetMap contributors, © CartoDB' }).addTo(map_object); cartodb.createLayer(map_object, layerSource, options) .addTo(map_object) .on('done', function(layer) { cdb.vis.Vis.addInfowindow(map_object, layer.getSubLayer(0), options, ['cartodb_id', 'number_of_cases'], { infowindowTemplate: $('#infowindow_template').html() }); var sublayer = layer.getSubLayer(0); sublayer.setInteraction(true); sublayer.on('featureClick', function(e, latlng, pos, data) { //alert("Hey! You clicked " + data.cartodb_id); }); }) .done(function(data) { });
