We are using Google MAP API V3 and CartoDB. I am trying to create the custom info box window as user clicked on CartoDB points marker. We have two layers on Google map first one for UK wide ward area polygon layer and other one is represent to the homes in each ward area by points marker on the ward layer and both the layers has individual feature click events(i.e. ward area polygon zoomed in on click and points marker will show the info box on click). But whenever I click on the points marker ward area layer which is behind that points marker also trigger feature click event with that. So I just want to trigger the points marker feature click events to show info box when user clicked on that. Any suggestion would be appreciated.
function drawWardOnMap() {
var sqlWhere;cartodb.createLayer(map, { user_name: username, type: 'cartodb', sublayers:[{ sql: "SELECT * from table", cartocss: $('#ward_heatmap_index').html().format('units'), interactivity: "units, cartodb_id, the_geom_webmercator, wd13nm, wd11cd, govtid, localarea, geometry " }] }).addTo(map).done(function (layer) { layer.setInteraction(true); GLOBAL_WARDS_HEATMAP_LAYER = layer; layer.getSubLayer(0).on('mouseover', function(e, latlng, pos, data, layerIndex) { }); layer.on('featureClick', function(e, latlng, pos, data, layerIndex) { if(layerIndex == 1 ) { getUnitDetailsInfoBoxStats(data, "yes-show-it"); return; } else if(layerIndex == 0 ) { getPointsOnMap(); } }); layer.getSubLayer(0).on('featureOut', function(e, pos, latlng, data, layerIndex) { });}).error(function (){ console.log('problem adding 2nd layer');});}
function getPointsOnMap() {
var _numSublayers = GLOBAL_WARDS_HEATMAP_LAYER.getSubLayerCount();console.log("_numSublayers: " + _numSublayers);if( _numSublayers == 1 ) { GLOBAL_WARDS_HEATMAP_LAYER.createSubLayer({ sql: _SQLString, cartocss: _CartoCss, interactivity: "rslid, non_pi_name, lrdid, lat, lang, postcode, district_name, unit_type_desc, wd11cd, wd13nm, govtid, localarea, ward_centroid_lat, ward_centroid_lang, total_mile_s_count" }) GLOBAL_WARDS_HEATMAP_LAYER.getSubLayer(1).setInteraction(true);} else if( _numSublayers == 2 ) { var _subLayer = GLOBAL_WARDS_HEATMAP_LAYER.getSubLayer(1); _subLayer.setSQL(_SQLString); _subLayer.setCartoCSS(_CartoCss); _subLayer.setInteractivity('rslid, non_pi_name, lrdid, lat, lang, postcode, district_name, unit_type_desc, wd11cd, wd13nm, govtid, localarea, ward_centroid_lat, ward_centroid_lang, total_mile_s_count'); _subLayer.setInteraction(true);}}
