I have a similar question to:How to join lines in QGIS for later using "lines to poly"?
I have a line shapefile that I wish to transform into a polygon shapefile.After making some cleaning and closing some gaps, the lines have this look:
After that I've made "Vector>Geometry Tools>Lines to Polygons" but I've got this:
I've made a detection for dangles... and I found a few on the places that seems to have that kind of error. Also... the location of those points, seems to be on the places the "lines to poly" process fails.I've tried to edit some of the dangles, snapping them to the nearest point to make sure there were no gaps... but running again the dangles detection, they're still there.This is how all the shapefiles (plus the dangles) look like:
Is this easy to fix without "going to the grass"?Why don't the dangles disappeared after snapping them to the correct place?
EDIT 1:I was able to clean all the dangles... I was not happy with the snapping... and I've retried once more. I guess I was trying the wrong ones... I tried a very simple one... and one by one I was able to solve the more complex dangles, some were overshoot lines that were behind other segments and other were the intersections.Well... after that, I was able to clean all the dangles!!!!
Now for the bad news... I got an error while making the Lines to Polygons:
An error has occured while executing Python code:Traceback (most recent call last): File "C:\PROGRA~1\QGISCH~1\apps\qgis\python\plugins\fTools\tools\doGeometry.py", line 348, in run success = self.lines_to_polygons() File "C:\PROGRA~1\QGISCH~1\apps\qgis\python\plugins\fTools\tools\doGeometry.py", line 519, in lines_to_polygons if inFeat.geometry().isMultipart():AttributeError: 'NoneType' object has no attribute 'isMultipart'Python version:2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]QGIS version:2.4.0-Chugiak Chugiak, 8fdd08a(...)]Does this ring any bells to you guys?
(by the way... the first question was about the dangles... now it's about the lines to polygons process, however... the question is "Can't transform lines to polygons" should I close this and start another or may I continue here?)
EDIT 2:user30184 asked for the Layer (no dangles at the moment):Lines shapefile
