Can't select geometry from Oracle DB using SQL
I'm trying to select the geometry field from an ArcSDE feature class in an Oracle 11g database (inside of a Python script via PyODBC). This is my query:
SELECT SHAPE FROM USR.FEAT_CLASSThis is giving me error ORA-24359: OCIDefineObject not invoked for a Object type or Reference, and I get the same for any other feature class. If I select another non-geometry field the query works fine, so I know it isn't a problem with the script or connection string. Has anyone else encountered this problem?
UPDATE:I have ArcGIS 9.3.1 installed locally but I'm not using it here, so I don't think that's playing a role. I'm not sure which version of ArcSDE is installed since I don't have regular access to the server, but I believe it's 9.3.1 as well. The Python script is using PyODBC to communicate directly with the Oracle server.
