I'm following this example from the esri-leaflet docs.
I have an ArcGIS Tiled MapService in ESRI:102696. So I'm trying to use Proj4Leaflet to project the service and use it in my application.
I found some proj4defs here and here. They do differ slightly, but neither seems to work.
This is the Map Service I am trying to use.
I put together a JSBIN example with the code below.
// The two proj4defs I found //var crs = new L.Proj.CRS('ESRI:102696', '+proj=tmerc +lat_0=35.83333333333334 +lon_0=-90.5 +k=0.999933 +x_0=250000 +y_0=0 +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 no_defs', { var crs = new L.Proj.CRS('ESRI:102696', '+proj=tmerc +lat_0=35.83333333333334 +lon_0=-90.5 +k=0.9999333333333333 +x_0=250000 +y_0=0 +datum=NAD83 +units=us-ft +no_defs', { transformation: new L.Transformation(1, 17627100, -1, 19798600), resolutions: [ 303.8194444444444, 217.01388888888889, 86.80555555555556, 65.10416666666666, 43.40277777777778, 20.833333333333332, 8.680555555555555, 4.166666666666666, 2.083333333333333, 1.0416666666666665, 0.5208333333333333 ] }); // pass crs into map constructor var map = new L.Map('map', { crs: crs }).setView([38.5432816667, -90.2688116667], 5); L.esri.tiledMapLayer('http://maps.stlouisco.com/ArcGIS/rest/services/Maps/PublicBase/MapServer', { maxZoom: 10, minZoom: 0, continuousWorld: true }).addTo(map); I'm not sure if the transformation is off or what. Any help would be appreciated.
