I am new to shapefiles so I maybe ask some stupid questions, sorry.
I want to plot a map of my region, with colour filled polygons using R. I have downloaded municipal (lines) and province (polygons) boundaries. I've used SAGA to merge municipal and province shapes to produce new boundaries (polygons) to read and plot with R and ggplot2.
I succesfully plotted the original province (polygons) but failed to plot new boundaries (polygons) with this error message:
Any help will be appreciated, thanks in advance.
You can find original boundaries here and newly created ones here
EDIT: Added link to data file lineas_limites_municipales_etrs89.dbf
And the original R code I used to plot original boundaries, not working for new ones (see error message above):
require("rgdal")require("maptools")require("ggplot2")require("plyr")# Reading municipal boundaries esp = readOGR(dsn=".", layer="lineas_limite_municipales_etrs89") muni=subset(esp, esp$PROV1 == "46" | esp$PROV1 == "12" | esp$PROV1 == "3") muni@data$id = rownames(muni@data) muni.points = fortify(muni,region="id") muni.df = join(muni.points, muni@data, by="id")# Reading province boundariesprov = readOGR(dsn=".", layer="poligonos_provincia_etrs89")pr=subset(prov, prov$CODINE == "46" | prov$CODINE == "12" | prov$CODINE == "03" )pr@data$id = rownames(pr@data)pr.points = fortify(pr, region="id")pr.df = join(pr.points, pr@data, by="id")ggplot(muni.df) + aes(long,lat,group=group) + geom_path(color="blue") +coord_equal()+ geom_path(data=pr.df, aes(x=long,y=lat,group=group),color="red", size=0.5)
Error en createPolygonsComment(p) : IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
Maybe I made some mistake when merging original polygons and lines to create the new boundaries. Shoud I check shp attributes?
