can't geocode with PostGIS 2.1.1
I don't know where's the mistake... I am using the process from the PostGIS documentation (http://postgis.net/docs/manual-2.1/postgis_installation.html#loading_extras_tiger_geocoder) . I created a database, installed the extensions, installed wget and 7zip to match the locations outlined in the doumentation, created profile in loader_platform (based on 'windows' profile, I am on windows 8), however when I try to run the Loader_Generate_Nation_Script generated by PGAdminIII I get lots of errors. The files are downloaded but I don't see any indication that any unzipping is done. If I ignore the errors and continue the process as explained in the documnetation, of course goeocoding doesn't work. I have the Loader_Generate_Nation_Script pasted here, and also the output from the Command Prompt Window below.
Can anybody help ?
LoaderGenerateNationScript:
set TMPDIR=\gisdata\temp\ set UNZIPTOOL="C:\Program Files\7-Zip\7z.exe" set WGETTOOL="C:\wget\wget.exe" set PGBIN=C:\Program Files\PostgreSQL\9.3\bin\ set PGPORT=5432 set PGHOST=localhost set PGUSER=postgres set PGPASSWORD=password1 set PGDATABASE=my6thGIS set PSQL="%PGBIN%psql" set SHP2PGSQL="%PGBIN%shp2pgsql" cd \gisdata cd \gisdata %WGETTOOL% ftp://ftp2.census.gov/geo/tiger/TIGER2013/STATE/ --no-parent --relative --recursive --level=1 --accept=zip --mirror --reject=html cd \gisdata/ftp2.census.gov/geo/tiger/TIGER2013/STATE del %TMPDIR%\*.* /Q %PSQL% -c "DROP SCHEMA IF EXISTS tiger_staging CASCADE;" %PSQL% -c "CREATE SCHEMA tiger_staging;" %PSQL% -c "DO language 'plpgsql' $$ BEGIN IF NOT EXISTS (SELECT * FROM information_schema.schemata WHERE schema_name = 'tiger_data' ) THEN CREATE SCHEMA tiger_data; END IF; END $$" for /r %%z in (tl_*state.zip ) do %UNZIPTOOL% e %%z -o%TMPDIR% cd %TMPDIR% %PSQL% -c "CREATE TABLE tiger_data.state_all(CONSTRAINT pk_state_all PRIMARY KEY (statefp),CONSTRAINT uidx_state_all_stusps UNIQUE (stusps), CONSTRAINT uidx_state_all_gid UNIQUE (gid) ) INHERITS(state); " %SHP2PGSQL% -c -s 4269 -g the_geom -W "latin1" tl_2013_us_state.dbf tiger_staging.state | %PSQL% %PSQL% -c "SELECT loader_load_staged_data(lower('state'), lower('state_all')); " %PSQL% -c "CREATE INDEX tiger_data_state_all_the_geom_gist ON tiger_data.state_all USING gist(the_geom);" %PSQL% -c "VACUUM ANALYZE tiger_data.state_all" cd \gisdata %WGETTOOL% ftp://ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/ --no-parent --relative --recursive --level=1 --accept=zip --mirror --reject=html cd \gisdata/ftp2.census.gov/geo/tiger/TIGER2013/COUNTY del %TMPDIR%\*.* /Q %PSQL% -c "DROP SCHEMA IF EXISTS tiger_staging CASCADE;" %PSQL% -c "CREATE SCHEMA tiger_staging;" %PSQL% -c "DO language 'plpgsql' $$ BEGIN IF NOT EXISTS (SELECT * FROM information_schema.schemata WHERE schema_name = 'tiger_data' ) THEN CREATE SCHEMA tiger_data; END IF; END $$" for /r %%z in (tl_*county.zip ) do %UNZIPTOOL% e %%z -o%TMPDIR% cd %TMPDIR% %PSQL% -c "CREATE TABLE tiger_data.county_all(CONSTRAINT pk_tiger_data_county_all PRIMARY KEY (cntyidfp),CONSTRAINT uidx_tiger_data_county_all_gid UNIQUE (gid) ) INHERITS(county); " %SHP2PGSQL% -c -s 4269 -g the_geom -W "latin1" tl_2013_us_county.dbf tiger_staging.county | %PSQL% %PSQL% -c "ALTER TABLE tiger_staging.county RENAME geoid TO cntyidfp; SELECT loader_load_staged_data(lower('county'), lower('county_all'));" %PSQL% -c "CREATE INDEX tiger_data_county_the_geom_gist ON tiger_data.county_all USING gist(the_geom);" %PSQL% -c "CREATE UNIQUE INDEX uidx_tiger_data_county_all_statefp_countyfp ON tiger_data.county_all USING btree(statefp,countyfp);" %PSQL% -c "CREATE TABLE tiger_data.county_all_lookup ( CONSTRAINT pk_county_all_lookup PRIMARY KEY (st_code, co_code)) INHERITS (county_lookup);" %PSQL% -c "VACUUM ANALYZE tiger_data.county_all;" %PSQL% -c "INSERT INTO tiger_data.county_all_lookup(st_code, state, co_code, name) SELECT CAST(s.statefp as integer), s.abbrev, CAST(c.countyfp as integer), c.name FROM tiger_data.county_all As c INNER JOIN state_lookup As s ON s.statefp = c.statefp;" %PSQL% -c "VACUUM ANALYZE tiger_data.county_all_lookup;" Windows8 Command Prompt output:
Microsoft Windows [Version 6.3.9600] (c) 2013 Microsoft Corporation. All rights reserved. C:\Users\user1>set TMPDIR=\gisdata\temp\ C:\Users\user1>set UNZIPTOOL="C:\Program Files\7-Zip\7z.exe" C:\Users\user1>set WGETTOOL="C:\wget\wget.exe" C:\Users\user1>set PGBIN=C:\Program Files\PostgreSQL\9.3\bin\ C:\Users\user1>set PGPORT=5432 C:\Users\user1>set PGHOST=localhost C:\Users\user1>set PGUSER=postgres C:\Users\user1>set PGPASSWORD=password1 C:\Users\user1>set PGDATABASE=my6thGIS C:\Users\user1>set PSQL="%PGBIN%psql" C:\Users\user1>set SHP2PGSQL="%PGBIN%shp2pgsql" C:\Users\user1>cd \gisdata C:\gisdata> C:\gisdata>cd \gisdata C:\gisdata>%WGETTOOL% ftp://ftp2.census.gov/geo/tiger/TIGER2013/STATE/ --no-pare nt --relative --recursive --level=1 --accept=zip --mirror --reject=html --2014-03-30 11:08:52-- ftp://ftp2.census.gov/geo/tiger/TIGER2013/STATE/ => `ftp2.census.gov/geo/tiger/TIGER2013/STATE/.listing' Resolving ftp2.census.gov... 148.129.75.35 Connecting to ftp2.census.gov|148.129.75.35|:21... connected. Logging in as anonymous ... Logged in! ==> SYST ... done. ==> PWD ... done. ==> TYPE I ... done. ==> CWD /geo/tiger/TIGER2013/STATE ... done. ==> PASV ... done. ==> LIST ... done. [ ] 197 --.-K/s in 0s 2014-03-30 11:08:53 (4.83 MB/s) - `ftp2.census.gov/geo/tiger/TIGER2013/STATE/.li sting' saved [197] --2014-03-30 11:08:53-- ftp://ftp2.census.gov/geo/tiger/TIGER2013/STATE/tl_2013 _us_state.zip => `ftp2.census.gov/geo/tiger/TIGER2013/STATE/tl_2013_us_state.zip' ==> CWD not required. ==> PASV ... done. ==> RETR tl_2013_us_state.zip ... done. Length: 8599274 (8.2M) 100%[======================================>] 8,599,274 251K/s in 24s 2014-03-30 11:09:17 (344 KB/s) - `ftp2.census.gov/geo/tiger/TIGER2013/STATE/tl_2 013_us_state.zip' saved [8599274] FINISHED --2014-03-30 11:09:17-- Downloaded: 2 files, 8.2M in 24s (344 KB/s) C:\gisdata>cd \gisdata/ftp2.census.gov/geo/tiger/TIGER2013/STATE C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\STATE>del %TMPDIR%\*.* /Q C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\STATE>%PSQL% -c "DROP SCHEMA IF E XISTS tiger_staging CASCADE;" NOTICE: schema "tiger_staging" does not exist, skipping DROP SCHEMA C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\STATE>%PSQL% -c "CREATE SCHEMA ti ger_staging;" CREATE SCHEMA C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\STATE>%PSQL% -c "DO language 'plp gsql' $$ BEGIN IF NOT EXISTS (SELECT * FROM information_schema.schemata WHERE sc hema_name = 'tiger_data' ) THEN CREATE SCHEMA tiger_data; END IF; END $$" DO C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\STATE>for /r %%z in (tl_*state.zi p ) do %UNZIPTOOL% e %%z -o%TMPDIR% %%z was unexpected at this time. C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\STATE>cd %TMPDIR% C:\gisdata\temp>%PSQL% -c "CREATE TABLE tiger_data.state_all(CONSTRAINT pk_state _all PRIMARY KEY (statefp),CONSTRAINT uidx_state_all_stusps UNIQUE (stusps), CO NSTRAINT uidx_state_all_gid UNIQUE (gid) ) INHERITS(state); " CREATE TABLE C:\gisdata\temp>%SHP2PGSQL% -c -s 4269 -g the_geom -W "latin1" tl_2013_us_stat e.dbf tiger_staging.state | %PSQL% Unable to open tl_2013_us_state.shp or tl_2013_us_state.SHP. tl_2013_us_state.dbf: dbf file (.dbf) can not be opened. C:\gisdata\temp>%PSQL% -c "SELECT loader_load_staged_data(lower('state'), lower( 'state_all')); " NOTICE: INSERT INTO tiger_data.state_all(region,division,statefp,statens,stusps ,name,lsad,mtfcc,funcstat,aland,awater,intptlat,intptlon,the_geom) SELECT FROM tiger_staging.state; CONTEXT: SQL function "loader_load_staged_data" statement 1 ERROR: syntax error at or near "FROM" LINE 1: ...,aland,awater,intptlat,intptlon,the_geom) SELECT FROM tiger... ^ QUERY: INSERT INTO tiger_data.state_all(region,division,statefp,statens,stusps, name,lsad,mtfcc,funcstat,aland,awater,intptlat,intptlon,the_geom) SELECT FROM t iger_staging.state; CONTEXT: PL/pgSQL function loader_load_staged_data(text,text,text[]) line 24 at EXECUTE statement SQL function "loader_load_staged_data" statement 1 C:\gisdata\temp>%PSQL% -c "CREATE INDEX tiger_data_state_all_the_geom_gist ON ti ger_data.state_all USING gist(the_geom);" CREATE INDEX C:\gisdata\temp>%PSQL% -c "VACUUM ANALYZE tiger_data.state_all" VACUUM C:\gisdata\temp>cd \gisdata C:\gisdata>%WGETTOOL% ftp://ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/ --no-par ent --relative --recursive --level=1 --accept=zip --mirror --reject=html --2014-03-30 11:09:18-- ftp://ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/ => `ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/.listing' Resolving ftp2.census.gov... 148.129.75.35 Connecting to ftp2.census.gov|148.129.75.35|:21... connected. Logging in as anonymous ... Logged in! ==> SYST ... done. ==> PWD ... done. ==> TYPE I ... done. ==> CWD /geo/tiger/TIGER2013/COUNTY ... done. ==> PASV ... done. ==> LIST ... done. [ ] 198 --.-K/s in 0s 2014-03-30 11:09:19 (12.6 MB/s) - `ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/.l isting' saved [198] --2014-03-30 11:09:19-- ftp://ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/tl_201 3_us_county.zip => `ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/tl_2013_us_county.zip' ==> CWD not required. ==> PASV ... done. ==> RETR tl_2013_us_county.zip ... done. Length: 73500446 (70M) 100%[======================================>] 73,500,446 186K/s in 3m 59s 2014-03-30 11:13:18 (301 KB/s) - `ftp2.census.gov/geo/tiger/TIGER2013/COUNTY/tl_ 2013_us_county.zip' saved [73500446] FINISHED --2014-03-30 11:13:18-- Downloaded: 2 files, 70M in 3m 59s (301 KB/s) C:\gisdata>cd \gisdata/ftp2.census.gov/geo/tiger/TIGER2013/COUNTY C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\COUNTY>del %TMPDIR%\*.* /Q C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\COUNTY>%PSQL% -c "DROP SCHEMA IF EXISTS tiger_staging CASCADE;" DROP SCHEMA C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\COUNTY>%PSQL% -c "CREATE SCHEMA t iger_staging;" CREATE SCHEMA C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\COUNTY>%PSQL% -c "DO language 'pl pgsql' $$ BEGIN IF NOT EXISTS (SELECT * FROM information_schema.schemata WHERE s chema_name = 'tiger_data' ) THEN CREATE SCHEMA tiger_data; END IF; END $$" DO C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\COUNTY>for /r %%z in (tl_*county. zip ) do %UNZIPTOOL% e %%z -o%TMPDIR% %%z was unexpected at this time. C:\gisdata\ftp2.census.gov\geo\tiger\TIGER2013\COUNTY>cd %TMPDIR% C:\gisdata\temp>%PSQL% -c "CREATE TABLE tiger_data.county_all(CONSTRAINT pk_tige r_data_county_all PRIMARY KEY (cntyidfp),CONSTRAINT uidx_tiger_data_county_all_g id UNIQUE (gid) ) INHERITS(county); " CREATE TABLE C:\gisdata\temp>%SHP2PGSQL% -c -s 4269 -g the_geom -W "latin1" tl_2013_us_coun ty.dbf tiger_staging.county | %PSQL% Unable to open tl_2013_us_county.shp or tl_2013_us_county.SHP. tl_2013_us_county.dbf: dbf file (.dbf) can not be opened. C:\gisdata\temp>%PSQL% -c "ALTER TABLE tiger_staging.county RENAME geoid TO cnty idfp; SELECT loader_load_staged_data(lower('county'), lower('county_all'));" ERROR: relation "tiger_staging.county" does not exist C:\gisdata\temp>%PSQL% -c "CREATE INDEX tiger_data_county_the_geom_gist ON tiger _data.county_all USING gist(the_geom);" CREATE INDEX C:\gisdata\temp>%PSQL% -c "CREATE UNIQUE INDEX uidx_tiger_data_county_all_statef p_countyfp ON tiger_data.county_all USING btree(statefp,countyfp);" CREATE INDEX C:\gisdata\temp>%PSQL% -c "CREATE TABLE tiger_data.county_all_lookup ( CONSTRAIN T pk_county_all_lookup PRIMARY KEY (st_code, co_code)) INHERITS (county_lookup); " CREATE TABLE C:\gisdata\temp>%PSQL% -c "VACUUM ANALYZE tiger_data.county_all;" VACUUM C:\gisdata\temp>%PSQL% -c "INSERT INTO tiger_data.county_all_lookup(st_code, sta te, co_code, name) SELECT CAST(s.statefp as integer), s.abbrev, CAST(c.countyfp as integer), c.name FROM tiger_data.county_all As c INNER JOIN state_lookup As s ON s.statefp = c.statefp;" INSERT 0 0 C:\gisdata\temp>%PSQL% -c "VACUUM ANALYZE tiger_data.county_all_lookup;" VACUUM C:\gisdata\temp>
