I am having trouble publishing a map file using ArcGIS publisher. This mxd is intended for use by ArcReader but I keep getting a "file access error message asking me to check that the file permissions are correct and that it is not already open by another application".I have been granted permission to publish on a shared drive and do not believe this mxd is being used by another application. Does anybody have an idea what else I can try to make it work?
Thank you so much.
Thank you so much.
