So I created my domain with coded values for my file geodatabase. I go to the feature class properties, fields tab, I create a new field, verify the data type of the field and domain matches and add that domain in the field properties below, click ok. Everything happens smoothly. Now when I immediately reopen the same feature class properties I dont see the domain I set 1 minute ago. The domain field is empty and I can see in Arcmap attribute table that the domain is not set to that field at all. And also now I cant edit or change any property of that field. It seems kind of locked. This happens every time I set a domain to a field. Why is the domain dissapearing? What am I doing wrong? The feature class is pre-created and I just want to add new field and add the domain to that field.
