Can you make a graph you can Pivot interactively ,graph limations
I have not really used Graphs in Arc that much.
I was wondering if it possible to make a graph that can be interactively changed to the selections that are input into it. Ideally something like a Pivot chart - Where the selections are being made from the TOC.
MadeUp Example
There is a feature class of polylines that equals a total of 1000 kilometres I Need to make a sub selection of a total of 100 Kilometres
The selection is a based on a visual selection and cannot be Automated.
As I select different lines I like to have a fast way of summing the total sum of the lines together.
My Workflow is
For each polyline within my feature class I make a separate layer, I label each line with something short and I then make a map of all lines , that I use a reference for lines I like to turn on.
From the dataset I export the this table to Excel and create a pivot chart
I then select lines in Arc and then make these Selections.
This works Ok and does give me the Desired Results
IDEAL OUTCOME
Link my layers to a graph , that interactively updates as selections are made or not made on the TOC , taking a the Culmative of a common FLD ID to make the total
If not via a graph , Are there any other options I could look at
