Can we no longer reference an ArcMap layer to get the spatial reference?
I'm currently using ArcGIS 10.2.1. In previous custom geoprocessing tools, I've used the following code to create a feature class in-memory, and set the spatial reference using an existing layer in ArcMap:
polygon = arcpy.GetParameterAsText(0)mem_point = arcpy.CreateFeatureclass_management("in_memory", "mem_point", "POINT", "", "DISABLED", "DISABLED", polygon)Where polygon is a layer in the ArcMap TOC. This has always worked in the past, but I just went to use one of the tools, and I got the following error:
Traceback (most recent call last): File "", line 23, in mem_point = arcpy.CreateFeatureclass_management("in_memory", mem_name, "POINT", "", "DISABLED", "DISABLED", polygon) File "",line 1800, in CreateFeatureclass raise e ExecuteError: ERROR 000622: Failed to execute (Create Feature Class). Parameters are not valid. ERROR 000628: Cannot setinput into parameter spatial_reference.Did this just recently change?
