Recently I ran into a troubling issue with ArcGIS (10.2.2) shapefiles. I transferred a shapefile with approximately 10,000 records from my local drive up onto a shared network drive at my office, using the basic function in ArcMap where you right-click the layer in the table of contents, select "Data," and then select "Export Data."
I then discovered that the copy of the file on the network drive had its attribute table significantly altered. The file could be used normally, and the table had the same number of records, but one particular record from the pre-corrupted version had somehow propagated itself throughout much of the rest of the table, overwriting nearly 25% of it.
This is fairly disconcerting, because I have always been under the impression that "corrupted" shapefiles simply will not open or will raise the classic "Number of shapes does not match number of table records" error.
Has anyone encountered a similar problem before and can confirm that something like this can be caused by upload/download of shapefiles between local and network drives? Are there other potential causes for an attribute table being altered in this unique way? What are some precautions against something like this?
Standard ArcGIS tools like Feature Compare & Table Compare successfully detect the issue, but it would be nice to have enough confidence in file transfer processes to avoid having to incorporate such relatively paranoid checks into my workflow.
