I am writing a plugin and have a postgis table which has EMPTY geometries in the geom column.
MULTILINESTRING EMPTYI am having crashes which just close QGIS. I have narrowed it down to the EMPTY geometries. Removing them seems to help.
I tried editing the layer without using my plugin and still have the problem. It appears that the EMPTY geometries in the layer are not acceptable.
I am using the EMPTY geometries as a marker as this layer is a geom "changes" layer where I need all attributes but only the geometries which are added or changed from a similar layer.
Is the EMPTY geometry not valid in QGIS? It should not cause a program crash.
