Can ogr2ogr read .kmz files? How?
Attempting a run-of-the-mill ogr2ogr process with a KMZ file failed:
FAILURE:Unable to open datasource `Rail.kmz' with the following drivers.Is there a trick? (Obvious workaround is to unzip the .kmz first, but that's sometimes clunky, and you don't know what the internal structure will be exactly.)
GDAL 1.11.0, released 2014/04/16
