I have a problem with my code (C# ArcObjects 10.1). We are trying to update and insert 10 - 15 rows at a time into a feature class hosted in ArcSDE 10.1 on SQL Server 2008 R2.
We have a feature class which is versioned with move edits to base and also has attachments which are photos.
I did some proof of concept code a few months back and thought I had everything working - I had tested inserting and updating a versioned feature class and inserting attachments associated with a particular feature. Looking back, I don't think I tried these at the same time - the feature class I tested inserting attachments may not have been versioned.
The issue I am facing is that my code was working fine and inserting and updating features, as soon as I added the attachment table - it stopped working and I get this error :
Objects in this class cannot be updated outside an edit session [SDE_CSO.DBO.DefinitiveList_COPY] at this line :
IFeatureCursor cursor = featureClass.Update(queryFilter, true); I am starting an edit session and edit operation before attempting this :
muWorkspaceEdit = (IMultiuserWorkspaceEdit)featureWorkspace; workspaceEdit = (IWorkspaceEdit)featureWorkspace; muWorkspaceEdit.StartMultiuserEditing(esriMultiuserEditSessionMode.esriMESMVersioned); workspaceEdit.StartEditing(true); workspaceEdit.StartEditOperation(); I did some googleing around and found a few old posts on the ESRI forums about a similar using using ArcPy and ArcObjects which seemed to suggest that using an Update cursor will not work with a table which is involved in a relationship.
So my question is.... is this possible with an update cursor - if so how? If not can someone offer an alternative solution?
