calling a script tool from a model using relative path
Hi I am new to ArcGIS and facing a problem in calling a script tool from a model.
I have the following file structure:
  • E:\MyFolder
    • MyToolbox.tbx
      • ScriptTool
      • Model
    • Scripts
      • myscript.py
The ScriptTool uses 'E:\Scripts\myscript.py' as the script file and is configured to use relative path. Hence, even if I move MyFolder from E:\ to D:\ , the ScriptTool is able to find myscript.py and it executes successfully.
Also the ScriptTool is added to the Model. The Model works fine if MyFolder is in E:\ but if I move MyFolder to D:\ , the Model cannot run as it is not able to find the ScriptTool.
Please help me by suggesting how I can add the ScriptTool to the Model such that the model uses relative paths to the script tool.
Thanks.
