Calculating pixels in leaflet
I am working with leaflet plugins, calculating distance between two points of a polyline or whole distance of joint/multiple lines
Work :I set up the script to measure the distance in meters when using image as map...
Script
function showPolygonArea(e) { featureGroup.addLayer(e.layer); var tempLatLng = null; var totalDistance = 0.00000; $.each(e.layer._latlngs, function (i, latlng) { if (tempLatLng == null) { tempLatLng = latlng; return; } //transformation experiment totalDistance += tempLatLng.distanceTo(latlng); tempLatLng = latlng; userDistanceVal = totalDistance / 100000; }); e.layer.bindPopup((totalDistance / 100000).toFixed(2) + ' meters'); e.layer.openPopup();}Problem :
here (1) i want to return the totalDistance in pixels instead of meters ....
(2)and here, how can i use layerPoint or containerPoint functin? (as i am struggling about the usage understanding)
I have so little experience in javascript, if doing or asking something stupid, please ignore...If its possible to do that way, please help....
Any kind of reference or help will be appreciated..thanks for your time
