Calculating minimum/maximum width for overlay of two polygon strips in ArcGIS or some
Is there some solution for calculating minimum and maximum width for overlay of two polygon strips? When I clip these strips the result is another strip with variable width about 1 km and 20 km long. How can I get minimum and maximum width for the clipped strip in shorter axis? I try script from Calculating Polygon Width in ArcGIS but it doesn´t suite with this issue.Is there some solution for ArcGIS 10.1? example: clipped strip with red line for minimum width, blue for maximumOr is it some solution solving the problem straightway without clipping inputs?
