Calculate Percent coverage using another raster, with dif resolution and orientation
I have a 0.5 meter raster that defines presence or absence (cells are either 1 or 0). I have another 5 meter raster, which I created. I would like to calculate a percent coverage of the underlying 0.5 meter raster and pull that value into the corresponding cell in the 5-meter raster. The rasters don't line up and cannot be adjusted.
One thing I now realize is that the cells are slightly less than 0.5 meters, .46999 to be exact. I ran block statistics, using a 10.638298 X 10.638298 rectangle (5/.469999), with snap raster set to, the slightly offset, 5-meter raster. That's taking a while to run, but I'm guessing that it won't work quite right. I also have a 5-meter polygon fishnet and I could also convert the .46999 meter forest cover raster into a polygon feature. Then I could calculate the area within each 5-meter 'cell'.
