Calculate Field based on field value in a second table
I have a table in a MSSQL Server Enterprise SDE database. I need to join a table from a MS SQLExpress Workgroup SDE database and then calculate 11 fields in the Enterprise table based on values in the Workgroup Table then remove the join.
I have tried to do this in model builder add it takes forever to run. I thought of selecting only those records that don't match before performing the calculate, but then thought maybe there were other ways to tackle this problems.
So now I am thinking that there are three alternatives that will do what I need in a quicker manor. My question is can anyone give insight on which would be faster or easier to do.
Option 1 Create a python code in ArcGIS 10.1 to perform the join select the mismatched records and perform the calculation then move on to the next field, when all done remove the join.
Option 2 Use FME Desktop to perform the same steps outlined above.
Option 3 Use SQL and perform the same steps above in Database
An input or suggestions would be appreciated.
