I'm a newbie in web-map application area.
I just found the small application in this tutorial interesting
I am a bit confused, because when i publish a map using geoserver and openlayer, I have to create a layer in geoserver first and this layer is fixed with a table from postgis and then use open layer to call geoserver to render the map.
- How can the tutor of that tutorial change the data source of the layer depending on the query input by the users ?
- It means there are ways to change the data source of one layer on the fly right ?
