As mentioned here I've tried to build the QGIS on Windows 7.
There are two methods one using Visual Studio Express Edition installer and the second one using MinGW.
I've found both of them broken and don't know what to do next
In building using Visual StudioThe link to visual studio actually installs the version 2010 but documentation assumes it version 2009. So "set VS90COMNTOOLS=%PROGRAMFILES%\Microsoft Visual Studio 9.0\Common7\Tools\" path is not found.
Also I'm confused about the context of this line:
So what's the way to build it?All I want is to change the title and startup photo of QGIS Desktop software.
Using another application I'm now able to change the title of running QGIS but don't know where to change the photo which shows "Loading plugins...".
If the path to bison and flex contains blanks, you need to use the short name for the directory (i.e. C:\Program Files should be rewritten to C:\Progra~n, where n is the number as shown in `dir /x C:``).
In Building using MinGW 4.2.1. MSYS link is not found(404) but when I try to build step by step I find XDR 4.0 not found(404) in this page
