Bug generating TIN, manually modified level curves
Having trouble while generating a TIN on a manually modified topography file.I'm a newborn of ArcGis, but I intensively tried to fix this bug, with no result.
As you can see, the bug deals about continuity in the generated model, the level curves seems to be logically disposed but the generated model proposes a big hole in the ground.
I noticed that the bug (unwanted changing of color = uncontinuity) was triggered by uncontinuous lines, probably created during the manual modification of this curves.I tried to merge, union, dissolve ans unsplit the lines with no effect on the generated model.
Thus, i'm currently lost and I would like to know if anyone already noticed this bug, and maybe have a piece of solution to give me ?
Nicely Yours,Clément
