Bootstrap navbar and leaflet zoom controls
I'm using the THE MAP GUY(DE) Bootstrap temple and applying it to leaflet using the code below. The issue I'm having is that the zoom-control doesn't toggle right on page load. It will only after you collapse and then re-expand the panel again. How can I get the zoom to toggle on load? What am I missing?
You can see the OL3 here: http://jumpinjackie.github.io/bootstrap-viewer-template/2-column/index.html.
JS
function applyMargins() { var leftToggler = $(".mini-submenu-left"); if (leftToggler.is(":visible")) { $("#map .leaflet-control-zoom") .css("margin-left", 5) .css("margin-Top", 50) .removeClass("zoom-top-opened-sidebar") .addClass("zoom-top-collapsed"); } else { $("#map .leaflet-control-zoom") .css("margin-left", 2 + $(".sidebar-left").width()) .css("margin-Top", 5) .removeClass("zoom-top-opened-sidebar") .removeClass("zoom-top-collapsed"); }}function isConstrained() { return $(".sidebar").width() == $(window).width();}function applyInitialUIState() { if (isConstrained()) { $(".sidebar-left .sidebar-body").fadeOut('slide'); $('.mini-submenu-left').fadeIn(); }}$(function () { $('.sidebar-left .slide-submenu').on('click', function () { var thisEl = $(this); thisEl.closest('.sidebar-body').fadeOut('slide', function () { $('.mini-submenu-left').fadeIn(); applyMargins(); }); }); $('.mini-submenu-left').on('click', function () { var thisEl = $(this); $('.sidebar-left .sidebar-body').toggle('slide'); thisEl.hide(); applyMargins(); }); var map = L.map('map').setView([40.91, -96.63], 4); L.tileLayer('http://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png', { attribution: '© OpenStreetMap contributors' }).addTo(map); L.control.mousePosition().addTo(map); L.control.scale().addTo(map); new L.Control.GeoSearch({ provider: new L.GeoSearch.Provider.OpenStreetMap() }).addTo(map); var locationFilter = new L.LocationFilter().addTo(map); $(window).on("resize", applyMargins); applyInitialUIState(); applyMargins();});//Bootstrap modal dragging$(document).ready(function () { $(".modal-draggable .modal-dialog").draggable({ handle: ".modal-header", cursor: "move" });});CSS
body { overflow: hidden; }.navbar-offset { margin-top: 50px; }#map { position: absolute; top: 50px; bottom: 0px; left: 0px; right: 0px; }#map .leaflet-control-zoom { font-size: 1.2em; }.zoom-top-opened-sidebar { margin-top: 5px; left: 2px;}.zoom-top-collapsed {margin-top: 45px; }.mini-submenu{ display:none; background-color: rgba(255, 255, 255, 0.46); border: 1px solid rgba(0, 0, 0, 0.9); border-radius: 4px; padding: 9px; /*position: relative;*/ width: 42px; text-align: center; }.mini-submenu-left { position: absolute; top: 1px; left: 1.2em; z-index: 40;}#map { z-index: 35; }.sidebar { z-index: 45; }.main-row { position: relative; top: 5px; left: 2px; }.mini-submenu:hover{ cursor: pointer;}.slide-submenu{ background: rgba(0, 0, 0, 0.45); display: inline-block; padding: 0 8px; border-radius: 4px; cursor: pointer;}HTML
Toggle navigation Map Viewer (2-column layout)
Submit
Layers
Open Street Map Bing WMS
Properties
Yada Yad Yad
Yada Yad Yad
Yada Yad Yad
Yada Yad Yad
</div>
